Ok, I searched and read almost every thread that dealt with the NA-T stalling problems... I am positive i have no vacumm leaks, and I do not believe it is the BOV which is causing my problems...
Set up - BL kit with t04r turbo, 680 injectors, walbro fuel pump, and the AEM.
I am stalling when coming to a stop, I will slow down, shift to nuetral and bam, car cuts off. It seems to be the same problem someone else had, it will stall 25% of the time. When I fire it back up its weak at first, then runs fine. Car has been tuned, made great numbers, but now I am having the stupid stalling problems
and it is taking the fun out of cruising. We had bumped the idle up to 1200 rpm and the stalling had cut back 90 to 100% but tonight I had the guys bump it back down because I dont want to Idle at that high of RPMs... but it stalled on me 4 or 5 times on the way home. Just wanted to know who all is having this problem, and suggestions.
