200mm vs 220mm rear diff
19K views 14 replies 9 participants last post by  ABU DHABI
#1 ·
How much stronger is the 220mm diff ? What is the highest hp on a 200mm diff ?
#2 ·
It's not so much how much power, but how the power is being applied on launch.
6 spd - go with 220mm, Auto - go with 200mm. Both diffs have had 1200+HP put thru them, but auto is much easier with a footbrake launch than a clutch sidestep.
Oh yeah, there is also the gearing thing; 3.13 or 3.26 (220mm) is perfect for a 6 spd, and 3.76 (200mm) is perfect for an auto.
Al
#4 ·
The only ratios suitable for an auto installed in JDM or US spec Supras came in the 200mm diff, which is roughly 8in (200mm/25.4mm/in = 7.87in) and the 220mm diff is roughly 8.7in (220mm/25.4mm/in = 8.66 in)
It's worth noting that I've seen other references to the 200mm diff specifying it as a 205mm, but I haven't bothered actually measuring any of the 200mm diffs I own. The 205mm value brings it to just over 8in (205mm/25.4mm/in = 8.07in)
The 200mm/8in diffs came with a large variety of ratios. If you are using the toyota automatic, the TT auto rear diff is the best with a 3.769:1 and a factory fitted LSD. Other options include the 3.916:1 92-97 SC400 diff, 4.082:1 SC300 5-spd diff, and the 4.272:1 NA Supra & SC300 automatic diff.
Note that the SC300 and NA Supra differentials will require swapping out the 3-hole companion flange that bolts to the driveshaft 'donut' in order to be used with a TT auto drive shaft. The SC400 and TT auto Supra use the larger companion flange, and that will be a direct swap so long as you're using a TT auto drive shaft. If you're using a 6-spd drive shaft, you may need to have the DS shortened slightly depending on your application.
Other info here: http://www.supraforums.com/forum/showthread.php?608545-JZA80-Differential-Info!
#7 ·
The car will have a viper T56 6 speed.
Many have tried this - none of them have been satisfied.
The 220mm diff isn't even available in ratios that would be T56 friendly as its ratio spread is entirely different than the V160/V161's.
What Toyota made is all we got, this isn't a diff where you can just call up Richmond and order whatever..
#10 ·
Most of the differential-grenading problems can be solved by using all of the billet differential mounts to help eliminate wheelhop, as well as avoiding drag radials entirely and using a full wrinklewall slick instead.
I've seen ~450hp BPU 6-spd cars grenade that 220mm diff because of wheelhop on drag radials.
#14 ·
