I am at a crossroads and need some guidance from the group. The crux, I am trying to decide between a new 2jzgte short-block or a forged short block from somewhere like induction performance. I do have a complete 2jzge vvti engine that I've torn down to the block with the crank still installed. The short block will be paired with the NA-VVTI head. Here's the overall plan.
Stage 1: 500WHP on pump gas.
Stage 2: 600WHP-700WHP using better fuel, either race gas or race ethanol (no E85 in my area😭) and install a cam and springs
I'm thinking of running something like a BW 364.5 SXE on a tubular exhaust (for better sound), but I am very open to suggestions.
Short-block costs.
-A new GTE block from the dealer in my area is $2.9k and I could pick it up this week (called and confirmed availability).
-Professionally built forged engines are around $5k and there's one nearby for $4.7k that a profession engine shop has laying around (BC proH625+ rods, Traum pistons, balanced ect). The only downside with that is it's a 10:1 engine and with the NA-VVTI head, that brings static compression even higher. I would be ok with the higher compression if I could still run around on high 400's on pump gas on BW 364.5 SXE, but I'm aware that it narrows the safe ignition timing window and increases cylinder pressure.
This is going in a Mk3 Supa Turbo. As far as timeline, I'm hoping to do the swap in fall '25. This will be self-tuned on an EMU black with a knock listening device (tuner nerd pro). I have successfully tuned my 7MGTE and have taken HP academy courses. This is just context I'm providing so you guys can assess what I can handle.
Hoping for recommendations. New OEM short block or professionally assembled forged. Is the 10:1 engine a viable option?
I should have mentioned, street car.
Short-block costs.
