Hello Ive Searched forever For a Good 2jz Swap for the 89+ supra and only found one decent thread in supramania so I Figure I would post mine to be a good sourcing for anyone else out their. This Is Just for a BASIC 2jz Swap Nothing fancy.
(Decided VVTI IS NOT THE WAY TO GO!).
Leaveing this thread alone,Going to build the 7m. don't go vvti unless you plan on staying under the 500hp range.
It is less hassle and cheaper for a non 2jz for 600+hp.. B IMHO I believe the VVT-I Is a better Motor for low to mid hp builds.
And ALSO All this Crap about a vvti being Weaker IS BS. They are the Exact same Engines internally same part numbers and everything.
the wiring harnesses are different and the intake cam/sensor and more things but for the most part Its the same motor. Not weaker nor stronger. just newer and more variables for improvement. I also hear their smoother powerbands
VVT-I Differences and Thread
Most of these parts Are Driftmotion <-click from Aaron and or you could source them here on the forums or Ebay<-click.
Another Swap Thread http://www.supramania.com/forums/showthread.php?66984-2JZGTE-MKIII-Swap-Info
7m wiring harness+2jz harness modified or sent in to Dr Tweak@ Arizona Performance price?
firewall dent in around 1/2"-1" for stock twins not really bad or hard
battery relocate for a clean engine bay
stock intercooler setup
Custom 3" DP to fit stock exhaust
Check Valve covers for leaks.. replace bolts/Seals 25$
Check Stock twins for leaks
This Is Just my List Yours Will be different as Everyone's will be.
Wants
intercooler kit 465$
Mishimoto radiator mvp 300$
Aem Wideband 200$
Needs
upgraded Motor mounts 130$
ujoints Ea 30$
Swap Parts
2jzgte Auto w/ Ecu 2k+-$ shipping
Rear sump kit 510$If needed HERE
1jz lightened flywheel 350$ or stock 269$ or used from the forums.
1jz bellhouseing 335$
1jz flywheel bolts aftermarkt 32$
7m clutch stg 2 425$
2jz throttle cable 60$+-
Mkiv ps lines 65$
Rear Seal 32$
Front seal 30$
Racing timing belt 73$ or greddy extreme 142$
Oil 30$
oil filter 12$
spark plugs 60$
Spark Wires 120$
Tranny fluid 30$
Serpentine Belt 25$
Parts 4187$
Safe swap price start 5,500$
Complete swap price 4800ish$
minimum cost of parts +-4200$
TSRM's
http://www.turboninjas.com/mk3supra/
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
Sourcing engine Websites
http://www.jdmenginedepot.com/
http://store.driftmotion.com/static/c-engines.php
http://www.jarcoinc.com/
http://www.jdmsource.ca/
http://www.japanmotorimport.com/
http://jrautoparts.makemesoez.com/
http://www.jspecauto.com/
haven't heard ebay is a great one but you can check it come majority of the times the sellers are Shops online.
Any Comments Feedback all welcome Thank you for reading.
Wants
Aem Wideband 200$
Needs
ujoints Ea 30$
Swap Parts
Mkiv ps lines 65$
Rear Seal 32$
Front seal 30$
Oil 30$
oil filter 12$
spark plugs 60$
Spark Wires 120$
Tranny fluid 30$
Serpentine Belt 25$
Parts 4187$
TSRM's
