HI, does anyone know what the torque spec is for the turbo oil feed banjo bolt?
I'm assuming the hole on the banjo needs to be perfectly aligned so the turbo's get the proper flow?
i have hand tightened it to about 20lbs.
I have a small leak on #2 turbo, maybe the copper washer is bad or not aligned?
Its a fresh motor, and upon firing it up , i noticed a nice leak.
That's all the leaks I've encountered so far.
