I have a 1991 Toyota Supra with a 2005 Aristo 2jzgte vvti
I bought 550cc High impedance injectors for it.
Will I be able to use my stock ecu or will I need to get a standalone ecu?
They are high impedance injectors not the stock low impedance from us supra.
Next question which turbo runs in low rpm and which is the 4k and above rpm?
Is the one that runs in low rpm in the front and the high rpm in the back?
I want to put a manual boost controller on the high rpm turbo.
Question 3 Has anyone upgraded the factory turbos to bigger compressor wheels?
I seen a place where you send off your turbos and they put 56mm wheels and 360 bearings in your stock turbos.
I want to keep the sequential twin turbo with the vvti to have that low end torque.
What is the best way to get the same effect with more power?
