best spark plug for 2jz-gte ??
1 reading
64K views 18 replies 14 participants last post by  slammed04tsx
#1 · (Edited)
What's the best spark plugs to be used on a 2jz-gte vvti and what gap size.. i searched a few forums everyone has different opnions.. any positive opinions on this
i heard njk 4644 but i finding copper ones are those the correct one
also heard the ik22 denso
#2 ·
Stock setup , or modded ?
#7 · (Edited)
^ No, the stock plugs at the stock gap will cause the car to miss under elevated boost. NGK 4644's are a step colder, and work very well.
#8 ·
If it's stock running stock boost I would also go with the stock plug since Toyota did a lot of testing to confirm long plug life, clean burning, overall good performance.
If you're running higher than stock boost on an otherwise stock setup, go one step colder on the plug and this is where you'll run into opinions about copper vs iridium etc. I think stock plugs were platinum but I forget. Iridiums last me at least a couple years and counting.
#12 ·
if Beyond stock boost go with NGK BKR7EIX Iridiums if you want ever lasting long plugs or what SP recommended me (no problems) is NGK copper 6282 (BCPR7ES) im running 24 psi for racing and 18psi for crusing... no misses at all... also if you're misfiring check your coilpacks. also my gap is at .025 that should be the LOWEST you go with stock twins. if lower than you shoudl check your ignition...
#14 ·
Read this:
Link
