Can you drift AUTOMATIC??
13K views 50 replies 31 participants last post by  msdg137
#1 ·
Wondering if automatic transmission can be competitively drifted, for example 2JZ twin turbo powered GS Lexus with MKIV automatic tranny??? Thoughts?
#2 ·
at what level? professionally? no.
locally in amature events? I suspect if the driver is good, it could be done. That is a heavy ass car to be tossing around tho...
#3 ·
Yes, it can be done and at the professional level. Check out www.bubbadrift.com - a friend of mine who just starting drifting this year and has made the Top 16 and Top 8 at Formula D twice out of 3 events. "One more time" with Rhys Millen at Wahl, NJ and "one more time" with I forget who at Houston Formula D.
Anna C.
bikiniracer.com
#5 ·
I have a video option episode where they show 5 D1 cars with automatics, couple of big toyotas in there (JZX100 & 110?). Don't know what they were doing (don't understand japanese) but they made a point of showing that these 5 cars were automatics running in the D1 competition. I keep thinking that Kazama was in there with his old nissan (pre-sponsorship?) not sure, but all 5 drifted very well.
I could find the video and figure out what volume it was for you, if you want...
#11 ·
Anna C.
bikiniracer.com
Werd. I saw him at Drift Atlanta, and it was awesome to say the least, not to mention that he's probably fighting odd weight distribution in that El Camino.
#14 ·
what kind of cage cost $50,000? That is bullshit. I think the bench racing has gotten out of control...
#17 ·
huh
turboracer1 said:
its possible but yeah not in competition level.
learn to read the entire thread. the bubba drift hellcamino was auto at one point and so are several other d1 cars.
YES YOU CAN!
makes it alot easier cause now you have both hands on the wheel and are not worrying about revs shifting wrong etc.
All you really need the first being a must is a lsd and suspension work the rest is up to you.
#19 ·
im quite sure major high competition drifting calls for shifting and clutching and engine braking, however its not like you cant select 1st or 2nd gear on your auto or turn you O/D off, im sure with the right parts you could drift a auto supra like it was on ice. i like autos, but i think if i was doing competition drifiting i would have a manual. but its all personal preference, auto drifting can has and will be done quite well, the driver just has to know the car well, control the auto well and be mindful of shift points weather the computer does it, or he does it. i think weight reduction and a lot of tranny work would be a must.
#21 ·
It can but it's not the same. you can build the tranny but you still are not directly linked to the engine. I drift my auto supra but it's not like drifting a stick you can't cluch kick.
#23 ·
i had a 1998 gs300 (2nd gen) with a handful of mods and a 170 shot of nitrous... and they only came in auto but the auto is gated so you don't accidentally put it in the wrong gear and it was possible to do up to about 80mph drifts... but you have to move the weight foward by using the regular brake and then downshift while using a light feint motion.... kinda hard to explain.... but it's dangerous if you don't know how grippy the surface of the road is since you can't rely on other stuff... oh and gs300's don't have a "conventional" e-brake so that's out odf the question (they have a shitty foot brake that doesn't do much)
#24 · (Edited)
Yes I drift my automatic SP67gt Supy. It was easier with the stock twins in SEQ. Usually I kick it in L and go drift and get crazy or use the MANU. I HIGHLY recommend 2 tranny coolers with your setup as well as tranny temp geuge. Heat is what kill auto trannies. Stock A/T setup is ok for amateur events but doing long slides at steep enter corners are very difficult on a stock setup, it will tend to fight back. Weight has to be the biggest factor, route your battery in the trunk, remove stuff you dont use, spare, tools and you'll be drifting. Just watch for those pot holes ;) But as a final remark, M/T is much better for so many reasons...
-Chris
#26 ·
Just install a hydraulic e-brake. Is it competitive? Can be. Is it cool to watch? Maybe. Will it slide at an early initiation with e-brake? Possibly with the right timing. Will you yank the e-brake for maximum angle sliding in the apex at 80mph? If you're hot shit. You gotta work with what you have if you slide with an automatic.
