I have used the search bar and I've read that ill need 20ft of hose but is that 20ft from fuel tank to fuel rail or 20 ft from tank to fuel rail and back? as im planning to use -10an feed line and -8an for return line
Hey man, I've been running a single -10 feed and -8 return for years, (massive, massive overkill for my set up ) and I never managed to kink the line over the diff at all. It can be done. Sorry I don't have photos to share unfortunately but I am currently pissing the braided lines off and going -10 feed, -8 return anodised hard lines.Too big means more expense on fittings, usually by about 30% from my findings. I'm currently running -10AN feed and -8AN return for my 1000rwhp+ build. I can tell you now, trying to run a -10AN teflon line over the diff without it kinking is almost impossible.
I'm purchasing a PHR Y block with a -10 to 2x -8's. The -10AN runs to just in front of the diff where I split it into two -8's that bolt up to the -8's on the PHR pump hanger.
You could potentially use fittings to help turn the corners without bending...
