Hey. Making the thread to discuss and find comparsions to my new setup.
Heres a simple conf of my blacky:
Stock jdm engine (105000km)
HKS264 cams
dual walbros
1600cc injectors (maximum duty <50% :rofl
custom T3 divided exhaust manifold, made by KKD motosport.
single Tial 44mm WG
HKS SSQ BOVwith bigger inside diameter custom made flange.
Holset HX40 Super with 16cm2( around .96ar) T3 divided hot side.
1.5bar of boost. (around 21-22psi)
Fuel used is 98E. European standard pump fuel.
Heres a picture of one run for you. Making approx 615hp and 763nm from wheels.
Boost line is purple.
Hitting 1bar (15psi) at 3400rpm
1.5bar (22psi) at 4200rpm
Heres a quick made comparsion to other standard cars and GarrettGT3582R .68ar supra on 1.3bar of boost.
All numbers here are hp and lb/ft.
VID:
http://www.youtube.com/watch?v=vccx8Dj2etk&hd=1
PDF dynosheet download:
http://www.megafileupload.com/en/file/261511/Supra-Dyno-07-06-2010---01-pdf.html
Im pretty happy with results. Dont need any more hp. This is a hobby track day car for me. pretty much as good as it gets with minimum lag.
Cheers
Kris
EDIT: 21.08.2010
Hey Guys!
Sry i have been away for long time.
But i can answer thiese questions now.
Everything is in fact, like its sayd at first post.
Im sorry if the numbers i told in post were not 1hp accurate. I didnt know that someone wants them to be so exact.
Each and every run is different while dynoing. Thats why numbers never match 1:1
I repeat once again because some of you didnt belive or didnt read correctly.
ALL NUMBERS ARE MESURED AT WHEELS! There was no drivedrain loss compensation included.
MAXIMUM PRESSURE: 256kpaA which roughtly is 1.5 BAR actual boost pressure at 100m above sea level.
MAXIMUM HORSEPOWER: 458,xxKW or roughtly 615HP
MAXIMUM TORQUE: 763,xx NM
For exact numbers you can download this pdf here:
http://www.upload.ee/files/1197788/Supra_Dyno_07-06-2010_-_01.pdf.html
Have fun!
HKS264 cams
dual walbros
single Tial 44mm WG
VID:
Cheers
Kris
EDIT: 21.08.2010
Hey Guys!
Have fun!
