go to pep boys,advanced auto parts,Get two individual sections of vacuum hose
go to home depot get a 1/4 copper tee,two barbed fitting that fit in the tee and fit the vacuum hose,
a short double treaded male end piece that fits in the copper tee
and a 1/4 inch ball adjuster valve
then you put it all together
gotta get down to the wastegate,pull off the vacuum line
run one vacuum line to one port,then the other vacuum line to the other port
screw the two barbed fittings into the tee,make sure there not on oposite ends of the tee.
screw in the double sided male end,and screw the ball adjuster valve onto that run both the vacuum lines onto the barbed fittings and then your done
close the valve all the way,and thats stock boost,open it alittle and the boost will go up,it only takes alittle.I wouldnt go past 8psi until you get,intake,downpipe,exhaust.then you can turn it up to 10psi,and go from there.I went 14.1s with that setup second cat in 10psi.Get a boost gauge and a air fuel gauge too.
