linelock, has enyone used it on tt auto tranny, how to install?
Hurst Roll Control #174-5000
The lines are a piece of cake! -3an lines you can get from Aeroquip. The fittings you will need are (1) m10x1.0 inverted flare female to -3 male. This goes on the brake line. (1) inverted flare male m10x1.0 to -3an male. This goes into the master cylinder.
I used a -3an 18" straight line hooked to the brake line fitting and line lock. And a -3an 18" one end a 90 degree hooked to master cylinder fitting and other end straight going into the line lock.
You will also need (2) -3an male to 1/8npt male fittings for the line lock solenoid. And (2) 1/8npt plugs.
