hydro VS. mechanical water pump?
12K views 17 replies 11 participants last post by  tkosupramk3
#1 ·
I was wondering what is a better way to go? I bought a 2jz that came with the hydro pump and didnt realize this until i took the pump apart i bought a mechanical replacement. Is this alright or should i stick with the hydro pump and route the pump so that it recirculates the oil inside itself? thanks for any info.
#5 ·
Its just like the 1JZ, they came in both mechanical and hydro pump setups. The aristo had hydro pumps and you can use a JZA70 hydro fan with the aristo setup. You can also use a 7MGE power steering resivoir for the hydro pump resivoir.
I have always liked the hydro fan and it pulls alot more air then the clutch fans =D
#15 ·
well since im not going to use the hydro fan would anybody like to purchase it from me? also going to have a 7mgte for sale here in the next couple of months and i have alot of spare parts for the 7m two heads one might have bent valves. i also have a w58 full tranny for sale cluth flywheel pressure plate whole thing shifter anyone?
#16 ·
Bumping an ancient thread.
If I get the 1J that has the clutch fan, could I just unbold the fan, & leave the pulley on & be fine? My plan is to run dual 12" electric fans w/ a thicker aftermarket radiator.
