My clutch kit only came with a new pilot bearing and a new clutch release bearing (thrust bearing). I resurfaced the stock flywheel and I'm pretty much good to go, but I have 1 question:
Should I purchase a new clutch realease bearing hub assembly to change that also, or is it safe to reuse these parts?
It looks like the stock clutch release bearing hub assembly is going to be a bitch to take apart. I really hate dealing with snap rings and things that press fit into other things.
Cliffs:
Should I also replace the clutch release bearing hub, plate washer, thrust cone spring, plate washer, wave washer, and snap rings along with changing the clutch?
Thanks,
Walt
Ref:
Cliffs:
Thanks,
Walt
Ref:
