I thought this was interesting so wanted to post it up. Might be helpful to some people. Here is a dyno comparison of the 6765, and off the self S366. This is two different cars, but nearly identical set ups with the exception of the turbo. Both cars tuned by the same tuner, done on the same dyno. Both turbos were at 20 psi.
The numbers appear low, because this on a dyno dynamic dyno.
First car:
Stock block/head
1000cc injectors
tublar manifold
4" DP/exhaust
AEM V2
6765 DBB
Second car (mine)
First car:
Stock block/head
800cc injectors
tublar manifold
4" DP/exhaust
Haltech sport 2000
S366 BW turbo
As you can see, the BW S366 is a tad bit lazier than the 6765 but ends up making about the same power.
owner of the 6765 car just did GSC S1's, BC valve train and made 515whp. I'm going to be doing the same exact cams and valve train with an addition of a light weight billet 11 blade wheel to my turbo next week.
I think its going to be an interesting comparison after my new wheel and same mods to see if I end catching up or beating the 6765 in spool.
I'll hopefully be comparing that in about two weeks.
First car:
Stock block/head
1000cc injectors
tublar manifold
4" DP/exhaust
AEM V2
6765 DBB
Second car (mine)
First car:
Stock block/head
800cc injectors
tublar manifold
4" DP/exhaust
Haltech sport 2000
S366 BW turbo
