My downpipe & elbow elimination was an ugly one-off part that did the same job as a DDP, but wasn't as pretty.
There seems to be two options available that I can find - first, the Titan Motorsports downpipe for the MK3, which uses a 'bellmouth' style inlet from the turbo and eliminates the elbow restriction as a result.
http://www.titanmotorsports.com/defdowwturel.html
The second, and the one that looks more like what I had, is the BIC performance DDP, available from BIC's product page:
http://www.bicperformance.com/products.htm
I would definitely add the $52 option for the DDP recirculation, as the open wastegate noise will attract a lot of attention, and I've heard from other Supra owners in Denmark over the years that aftermarket modifications are illegal, so that kind of attention would be bad, I'm assuming. The second part is that the BIC pipes are built to order and I'm not sure if BIC ships parts to Europe, so I'd send an Email first before buying it.
Since Titan Motorsports ships all over the world on a daily basis, and they usually stock their own parts, the Titan would likely arrive much sooner with much fewer headaches shipping it to Europe.
I suspect the DDP might edge out the Titan DP in overall performance, but I also believe that you'd need to be running a MUCH larger turbo in that tiny CT26 exhaust housing to ever notice a significant difference.
Yes, the Toyota Type-IV ATF should be available at any Toyota dealership.
Yes, so long as the rest of the car is in good shape and the maintenance has been addressed, and your local pump fuel can support that much boost safely, yes, that should be a reliable setup. If you decide to get one of the Sound Performance bolt-on PTE turbos for the 7M, I'd suggest the addition of an adjustable fuel pressure regulator, as that will help extend the capabilities of that fuel system once you've got a high pressure pump in place.
With the shimmed accumulators, fresh Type-IV trans oil, and a large trans cooler setup, yes I do believe that would perform reliably at the HP you'll be making
So long as there isn't anything wrong already with the transmission, or the transmission isn't excessively worn. These cars are getting old, after all.
Hope that answers all of your questions! :beer:
