Just ordered a set of TE37 SAGA SL, 18 inches,22 offset on both with 9.5/ 235 front and 10.5/275 rear. Dealer here in Japan said it might catch my caliper?? What see what y'all think.
18x9.5 +22 and 18x10.5 +22 doesn't fit a stock body JZA80 at all. Unless you're into lots of 'poke' past the fender, or the super stretched tire and tilted-wheel baka camber thing with tons of fender rolling, and I personally find that incredibly distasteful on a JZA80.
Neither will clear stock TT calipers, and using spacers to clear will only make the poke far worse.
In my opinion you need to call your wheel vendor and cancel that order right now.
Instead, get TE37 Saga S-Plus (not the SL) in 18x9.5+38 Face-4 for the front (use a 3mm spacer to clear the calipers) and if you absolutely must have a deeper face in the rear, get an 18x11 +45 Face-5 for the rear, which will fit like an 18x10.5 +38 as far as fender clearance goes, but it'll tuck further in towards the suspension obviously.
If you absolutely must have the SL, I'd go the same spec in front but an 18x10 +40 in the rear. This will obviously have the same Face-4 spoke profile though.
For clarity's sake:
Early/oldschool TE37's in 18x9.5 +40 with a flat face clear the stock TT calipers.
The later TE37 concave "Face-4" 18x9.5 +38 need a ~3mm spacer to clear - and not because of offset, but because of the spoke profile.
That's on the older TE37 offerings, my friend - an 18x9.5 +40 front 18x10.5 +45 option doesn't exist in the TE37 lineup anymore.Front should be +40, rear +45.
I'm glad you could get your order changed!So I changed my front to +45 and rear size 10 and +40. They should fit now?
Thanks for the insight, and good looking TE37s you have there. I think a lot of people get wheels with too low of an offset for clout.9.5 +38 will fit nicely. If the face/concave is similar to SL then you'll need that 3mm spacer.
Pics for reference. I'm running 265F (stock fenders) and 305R cut rears but my offset would work with stock fenders on a 285-295mm tire.
OP - hope this helps... I'm not wanting to piss on your thread but hoping you see the benefit of proper offsets. They allow nice width for superior grip.
Sounds like you got things squared away budy.So I changed my front to +45 and rear size 10 and +40. They should fit now?
Having done 295/30's on an 18x10.5, I wouldn't do it again. I would go 285/35 or 295/35 and adjust the suspension as needed to end up with the same wheel gap/fender clearance etc. I think the A052's are available in a 295/35.I dunno what kind of power you're putting down, but I don't want drag radials for a litany of reasons, so here's my plan.
Front: 265/35 (stock diameter) A052s on 18x9.5 +38 S-Plus.
Rear: 295/30 (stock diameter) or 315/30 (about .5" greater than stock diameter) A052s on the 18x11 +45 S-Plus
Trofeo Rs and GY F1s are supposed to hold well in a straight line for a circuit tire too. The most common option is probably the R888R. One of the Rad Dan customer builds Larry Chen did an expose on used the Toyos, I think it was the 305/35 R888Rs, that were right at the cusp of breaking loose at 650-700whp with a well tuned Borg Warner 8374.
It'll be pretty close on your existing BBS 18x10 +37's and 100% unmodified/uncut/unrolled fenders, but I'd advise trying a sticky 275/40 or 285/35 with those wheels before giving up and going with new wheels. More tire height and sidewall is key for straightline traction.My car is likely going to be in the 550-600 rwhp range once I finish my transmission upgrades and get back on the dyno. The factory clutch is limiting me right now.
I just want a setup that will work without fender modification.
I really appreciate the advice. The A052s are a bit wider than typical for their size group. A quick look on Tire Rack shows the following for the A052s:Having done 295/30's on an 18x10.5, I wouldn't do it again. I would go 285/35 or 295/35 and adjust the suspension as needed to end up with the same wheel gap/fender clearance etc. I think the A052's are available in a 295/35.
The taller tire and more sidewall pays huge dividends on straightline traction with any given tire compound. Yes, there's a tire height difference, but it's not enough to mess with the factory ABS system or anything like that.
Alignment settings also make a huge difference in straightline traction. Baseline with the 'Lance Alignment' specs and adjust from there, reducing camber further depending on rear suspension stiffness & travel etc.
