I have an 87 MKIII Turbo and my temp gauge stopped working after disconnecting the TEMS to change my suspension. Coincidence or did something get unhooked? Any info would be helpful.
Here's a helpful picture of sensors around the thermostat housing and side of the water neck. The cold start sensor on top is obscured by the vacuum lines in the photo though. You can check the resistance values against the specification in the manual if need be. Could be just a loose plug or broken hanging wire. The gaffe I always fall into is unplugging the oil pressure sending unit when messing around in that area. Its a real eye-opener to see no oil pressure showing up on the gauge.
Thank you for the picture! My uncle's MKIII temp sensor seems acting up as well. We will take a look at it right after we finished installing the exhaust and cold air intake kits on the current TJ project. My cousin recently worked around the sensor area and probably moved something.
The ground wire for the sensor is on the intake manifold which can cause issues sometimes too. If it become completely discounted there your temp gauge will be maxed out at hot FYI.
Related Threads
Supra Forums
posts
7.6M
members
113K
Since
2001
Supra Forums is the largest online Toyota Supra MKI, MKII, MKIII, MKIV and MKV owner's club community. Discuss DIY, modifications, and upgrades.
