**Undercover Performance 650 whp NA-T MKIV Supra Build Version 2.0**
3.9K views 24 replies 15 participants last post by  bkfill
#1 · (Edited)
Hey guys,
Garth from Undercover Performance has been working on my NA-T MKIV Supra for the past couple years. My experience has been nothing less than FANTASTIC. I am in the process now of upgrading a few parts from my old build. I will update the thread with photos as we progress.
New plan for 2012:
1. Install a full VVTI COP ignition swap (adios ugly distributor cap)
2. Pull motor and have a full engine bay re-spray and wire tuck
3. Install new turbo goodies - TiAL 44mm WG, SRT Tubular Manifold, .81 Twin Scroll Exhaust Housing
4. Install new GS400 pumpkin with my BNIB Toyota TRD LSD - nom nom nom
5. Re-tune and break 600 whp on pump gas
6. ABS delete with XRP lines and fittings
7. Install S2000 seats onto Supra seat brackets
8. Install custom shifter bushings
9. Relocate Billion Power Steering Reservoir and Greddy Radiator Breather
10. Install custom catch can with -10 AN SS lines - can be done once ABS is removed
11. Install interior upgrades - ARC Titanium Shift Knob, TTC Dash Rings, Takata Harnesses, Harness Bar
Current Mod list:
Engine:
2JZ GE Engine Block - decked, honed, and bored to spec
Wiseco .040 Pistons
Eagle Rods
ARP Head Studs
ACL Race Bearings
ACL Main Bearings
Cometic 3mm Headgasket
Stock 2JZ GE Head - hot tanked, new hardware, 5 angle valve job, recent valve adjustment (the works)
Driftmotion Pulley Set > Upgrading from stock
PHR Solid Engine Mounts > Upgrading from stock
BDL Cam Gears > Upgrading from stock
Gates Racing Timing Belt
Blitz Racing Oil Cooler with Relocation Kit > Upgrading from stock
Transmission:
Stock W58 5 Speed
Refinished Stock Flywheel
RPS Organic Street Clutch
Genuine C's W58 Short Shifter > Bling
Billet Aluminum Shifter Bushings > Upgrading from stock
Turbo Setup:
Precision T67 .68 AR Journal Bearing Turbo > Upgrading to .81 twin scroll
Precision 750 HP FMIC Core
Greddy FMIC Piping, Couplers, and T-Bolt Clamps
Blitz Dual Drive BOV
Tial 40mm Wastegate - 7 psi spring > Upgrading to a TiAL 44mm
Vibrant Vacuum Block
Hallman Pro RX MBC - set to 13 psi > Upgrading to a Blitz DSBC R-Spec
Dave H Exhaust Manifold > Upgrading to an SRT tubular manifold
Dave H Downpipe > Upgrading to a custom 3"-4" V-Band downpipe and midpipe
Apexi GT Spec 3.75" Exhaust
eBay Intake Pipe > Welding on -12 AN fitting for catch can breather
HKS Mushroom Filter
Accufab 90 MM Throttle Body
Ford TPS Sensor
MVP IACV Block off plate
Custom FFIM
Custom Throttle Cable
Electronics:
IS 300 VVTI COP coilpacks > Upgrading from stock distributor
DS62 Ignitor > Upgrading from stock distributor
7M GTE CPS with Driftmotion Billet CPS cap > Upgrading from stock distributor
Greddy 60 mm Electrical Gauge Set - Boost, Fuel Pressure, Oil Temp, Water Temp, EGT
Speed For Sale custom glove box insert
AEM EMS Version 1
AEM Wideband o2 Gauge
Braille Lightweight Battery > Upgraded to an Interstate
Fuel system:
PHR Dual Feed Fuel Rail
Aeromotive A1000 FPR
1000cc Siemens Injectors > Send for flow testing
(3) Walbro 255 LPH Fuel Pumps
Modified NA Fuel Pump Hanger
Summit Relays
-6 and -8 AN SS lines
Aeromotive 10 Micron Inline Fuel Filter
Wheels,Tires, & Brakes:
SSR Competition Wheels - 17x8.5 (13 lbs) 17x9.5 (14 lbs) - Anthracite Color
SSR Competition Wheel Caps and Valve Stems
Firestone Firehawk Wide Ovals - 245/40/17 Front 285/35/17 Rear
Wilwood 4 Piston Calipers
Wilwood 13" Cross Drilled Rotors
Wilwood Pads
Wilwood SS Brake Lines
Interior:
Full 98 Interior Panel Set > Installed
Titan Motorsports Rear Seat Delete > Installed
Takata 4 Point Racing Harnesses > Upgrading from stock
ARC Titanium Shift Knob M12x1.25 > Upgrading from stock
TTC Dash Ring Set > Upgrading
S2000 Black Leather Front Seats > Custom install with Supra seat brackets
NRG Racing Harness Bar > Upgrading to accommodate seats
Miscellaneous:
Custom catch can w/ -10 AN SS lines to valve covers
Billion Racing Power Steering Reservoir > Baller
ABS Delete with SS XRP lines and fittings > Upgrading to clear up engine bay
Greddy Radiator Breather Tank
NEW 2JZ GE Full Engine Gasket Kit
NEW 2JZ GE Crank Gear
NEW 2JZ GE Water Pump
NEW 2JZ GE Oil Pump
NEW 2JZ GE Distributor Cap & Wires
NEW 2JZ GTE 1998 Supra Radiator
All Royal Purple Fluids - Motor Oil, Syncromax Transmission Fluid, Rear Diff Gear Oil
Used 2JZ GTE PS pump w/ Titan reservoir - had to run this to clear the FFIM
NEW NGK Spark Plugs
NEW Gaskets for everything else - manifolds, dp, exhaust, etc.
NEW Sensors for everything as well - AEM 3.5 bar map sensor, AEM IAT sensor, AEM Wideband o2, 2JZ GE o2 sensor, etc.
I will update the thread as the build progresses. Stay tuned...
UPDATE: Parts highlighted in orange are whats in store for early spring 2012 build.
#7 ·
The W58 is still holding fine with my RPS Max Street Disc. I am looking to upgrade to a twin disc because from what I've heard/read they can be a W58 transmissions best friend. Anyway, in my opinion the clutches lifespan depends on a few things:
1. Amount of torque/horsepower
2. Driving style - if you beat on it all day and launch it from a dig constantly, then yes it will blow up like the rest of the W58 drivers out there
3. Ability to actually drive - some people love to just slam the gears in a W58, but in all honesty just shift a little slower and smoother and let the HP of the Supra make up for the lack of slamming the gears
#5 · (Edited)
UPDATE: The build is 95% complete. Just waiting on a 90 degree aluminum butt weld to mount the turbo and then finish some welding to the exhaust.
Old motor being pulled
Old motor out
Old unpainted fugly engine bay
NEW painted engine bay
Cleaned motor in new painted engine bay with new exhaust manifold installed
Intake manifold side
Almost fully assembled
High resolution
#6 · (Edited)
Old Pictures:
100% bone stock 79k miles when I bought her
Old 2JZ GE motor being pulled
Old engine bay
New motor with Boostwerx manifold
Old turbo and intake installed
Precision 750 HP FMIC installed
Old engine bay
#13 ·
Stay tuned, LOTS OF PICTURES to come. Just need to get the pictures off Undercover Performances camera.
#22 ·
Thanks Anthony! We need to schedule and end of summer meet soon, maybe at Undercover Performance if I talk to Garth.
