Over 7 years years ago when I asked the service manager at my local Toyota dealer about the AC service campaign on our 89-92 Supras TXVs needle sticking problem, he said it never expires and they would either add a special lubricate to the AC system if there currently was no problem with the TXV's needle sticking or replace the TXV if it was stuck open or close and reclaim/recharge the system back with R12 as, "Toyota did not approve of converting the system to R134A." Not making that up as that really surprised me that they still had R12. They did! I was able to take a 30 lb tank of R12 when I did my AC mod in 2014 and was told to just keep it. It helps that I know the parts manager and owners son very well. So I ended up getting about a third of a 30 lb tank which I currently have stored in basement. I made up and installed dual staggered AC brand parallel flow condensers ( model AC39293P when they were available) piped in series one behind the other along with a larger displacement ND PA20 compressor off a 92 Cressida which is bigger in both diameter and length than the stock PA17 on our Supras. It bolts right up to engine when using the different Cressida's compressor bracket. Both use the 7M engine for those that didn't know. Same AC idler, same belt but you must retain the Cressida's clutch assy so that clutch, crank and idler pulleys are all inline. I had to adjust the superheat adjustment screw on the stock R12 TXV to feed more liquid to evaporator as I was pulling down to below 15 psi with the larger PA20 compressor. I added 2 extra ounces of mineral oil to system for the second condenser.
I honestly have serious kick ass freezing cold R12 meat locker AC, 34-35 degrees on the hottest/humid CT days from center louvers. Since doing this over 7+ years ago and re-O ringing every joint with the newest Toyota red O rings, I have yet to add a single ounce of R12. Sight glass is still completely clear on hottest day with 1500+ rpm, max recir., highest blower and all windows down. Black car, black leather seats with shadow gray interior is seriously cold on hottest day. I have such capacity, the AC clutch cycles on the hottest day in driveway at idle due to evaporator's thermistor temp. cut out.
Of all the mods I've done in 17 years, this is the best one!
