What the hell!?
1.1K views 14 replies 7 participants last post by  nottooslow
#1 ·
My car has been acting real funny lately. About a week and a half ago, the car was throwing codes 12, 34, and 51, then the next day 12, 21, 34, 43, and 51, then the car stopped turning on with the key! I had full voltage but the only way to turn it on was to push start it. So for the time being I ran an alternate wire to the starter and the battery so I could start it with a switch in the cab. That worked great for about... 2 days. The last time I started it up, it was turning over real slow but started up fine *shrug* After that it quit on me. Now I am getting code 11. I have gotten code 11 a couple times and then it goes away. Could it be that I have a bad ecu? It seems that every time I get into the car I get different codes. My car is an electric nightmare! I am kinda feeling that there isn't much you could tell me (I could be wrong) But if anyone that lived near me could come and help me out I would appreciate it very much. Thanks for the help.
#4 ·
i'm basing that idea on a post i saw 3-4 weeks ago about codes cause i had weird codes pop up on mine (3 at once, reset and so far so good) but anyhow one of the replies noted a bunch of places there are grounds. i think any wiring problem can throw weird codes and it sounds to me like a good place to start for you because they aren't regular or consistant. good luck. maybe someone can remember the post i think i saw... something about grounding under fuse box, etc.
#9 ·
Please don't tell us you mean to say you're not aware of what the diagnostic codes are... if this is the case, you'll get a quicker answer searching for "diagnostic codes" than by waiting for a reply..
They're also discussed in the SOGI tech-tips... or they were, at least.
#12 ·
Would a bad ground have to cause a code? I ask b/c I think there may be one somewhere but can't find it and have no codes. I guess if it doesn't trigger more than a certain amount of time it won't store the code. Does anyone know if a bad ground will always trigger a code?
#13 ·
i wouldnt rule out a bad alternator just yet, my friend had a brand new alternator and his truck, yes i know its not a supra, but anyways it kept messing up, he tried everything to fix it and finally gave up and took it to a shop and the alternators voltage regulator was bad. hth
