After seeing a bunch of wide tires on Vettes, Vipers, GTR's etc, I have been on this kick to run a 335/30/18 on the rear of my car. After researching a bit, I find that it fits on the stock body, however CCW doesn't release offsets, and in the second set of pictures that I'll post, the tire size isn't listed.
Right now I have a 18x10.5+37 in the rear with a 295/35/18. The car is very very low, you can't get a finger between the tire, and the fender. Now if I convert that offset to a 11.5 inch wheel, I get a 10x11.5+50 which makes the new wheel .3mm tucked compared to the old wheel, so my question basically is if that offset will clear in the inside between the tire/wheel, and my coilovers. I'm posting this because I don't want to spend 4 grand on a set of wheels and tires to find out that they don't fit.......
CCW's 18x11.5 with a 335/30 no offset since they are CCW's naturally:
Second set but I don't know the tire size.
My car is a bit lower then it is in this picture:
Camber has since been put to lance alignment specs, so the rear tires sit flat:
