i cant get the oil filter off
2.4K views 47 replies 32 participants last post by  NashMan
#1 ·
hi i have had this car for a while and its been jsut sittin and i decided to change the oil, so i got the oil out and all and went to get the filter off and it wont budge, we have tried eeverything except putting a screw driver through it, anyone have any ideas or is there a special tool i need or what cause it wont move..
#4 ·
IF (big IF here) you can't get it off after all that you can always hammer a fat screwdriver through the middle of it and use it to turn the filter.
Careful though, oil will definitely come out all over the place. I had to do this once with a friend's car - the damn clamps were just crushing the filter and it wouldn't come off any other way.
don't cut yourself either.
#6 ·
i'd rather not use sandpaper (where the grit could flake off) near my oiling system. :faint:
that's just me, though. it's the easiest to pull the accordian pipe and get to it that way. plenty of room.
heh, that's a problem of the past for me, as mine is located near the passenger side tow hook, and it's more than 2x the size of the OEM filter. ;)
-shaeff
#8 ·
BTZ said:
a general filter wrench will do the job. I had the same problem so i forked out the $10 for the tool.
The first time i changed my oil filter on my MK3 was a bitch. I didnt have enough room for the filter wrench to turn. I could get it in there but then I didnt have enough room to turn it. I ended up resorting to the old screw driver and hammer. Now I make sure to use the fram oil filters with the grip. I love those damn things.
#9 ·
You should of seen my ass trying to get that filter off for the first time, man o man, i took it up to my school to have it jacked up so i can change the oil. i literally sat there for about 45 min trying to get it off , man it was a bitch, from then on i just go get my oil changed at a proffesional place, let them suckers deal with it :naughty:
#10 ·
Yeah first time I changed mine it literally took me about 45minutes too. I swear it felt like the fucking oil filer had never been removed. That fucker was stuck on there hard core. It was stuck so bad that when I put the screwdriver through it the oil filer started tearing when I was loosening it.
#13 ·
you do know that fram oil filters are pretty much the worst you can put on your car, right? :( go with wix/napa gold, mobile 1, perolator. anything but fram.
-shaeff
#14 ·
rubber gloves & strength FTW. Tool works aswell.
#15 ·
Mobil1 FTW!!!
Fram = suxor
#18 ·
dont poke your eye out now!
#23 ·
supraMoe72 said:
dude,get a screw driver,and punch it through the filter and twist the screw driver,it'll come right off
um.. that's what he said he did
