Thanks to all for the kind words. I have been doing these Supra LED upgrades for about 5 years. There was a thread at one point for my work here.
http://www.supraforums.com/forum/showthread.php?682656-My-speedo-and-HVAC-LED-conversion-by-stu. I also do have a specific FB page dedicated to all my LED stuff.
https://www.facebook.com/Stu-Hagen-361958853881688/ It started out as something for my Supra only and blossomed once people asked me to do theirs. 500 HVACs and Clusters later I am still doing these.
My work isn’t anywhere near the cost (I think) on what the LED guys do. I used to sell these "bulb kits" but they just do not do justice for the overall lighting. So I designed custom made circuit boards. These are somewhat plug n play, but the work involved modifying all the internal plastic pieces and wiring is a bit much. It is also imperative that you replace ALL the on-board resistors otherwise the indicators are blinding. It has to be done just right so it lasts forever; being cautious of not shorting out the LEDs to any bare metal. I have done a few previously modified HVACs and I wonder how they lasted as long as they did. My boards are double insulated to protect against shorting. They provide very even lighting and can be made in whatever colors you want. It does take a lot of work doing a HVAC, like 8 hours + but the finished product is a lifetime thing.
This is an older shot of the actual circuit boards that go inside the unit.
Here is a picture of the lower row installed (like the picture above from Jdmsup)
This is a picture of a finished unit in my "standard" lighting color scheme.
For the instrument cluster I use micro needle circuit boards and LED strips.
Micro LED circuit boards to illuminate the needle.
Internal wiring using 1 meter of 5050 7k LED strips; Positioned to give best overall lighting.
Finished cluster in my "Standard" style and faces.
I have over 50 different style faces for LHD and RHD. What I don’t have can be made quite easily.
