I have been on the bandwagon of "racelogic solves your traction issues" since in theory it sounds great, but in reality, there is a bit of disconnect.
Some recent highway pulls have been making it obvious that although the racelogic prevents (or aids in preventing) you from a major spin out, without traction, you're still left with a disadvantage.
Case in point: Local 997 with some minor upgrades (note these cars do 10s @ 130ish stock, driven well), 2nd gear pull:
Supra vs 997, 2nd gear roll
I am probably in my 800whp trim, 30psi boost on the 6768 with pump and meth. Tires are 295/45 ET STreets, 29psi in each. Yes, it was about 25degF out, and obviously this was one of the first pulls of the night, no burnout done on tires.
The porsche is no joke, it will pull hard in the lower gears. You can hear my traction control kicking in 2nd gear. Car stays straight, but it doesn't pull hard. 3rd gear and 4th gear are rock solid. It took me 5th gear around 140mph to pass him.
If I had no traction control this night, I would have spun 2nd, hit the rev limiter, and shifted into 3rd at 3000rpm, waiting ages for the turbo so spool up. What you can see is the turbo spools up fairly quick once I shift into 3rd. So, it isn't a complete wash out.
Here is another pull with the same Porsche, except I hit the gas as soon as he did his 3rd honk (previous pull I was slighly distracted):
2nd Pull with 997
What sounds like rev limiter is actually the Racelogic pulling fuel and keeping the tires from spinning. If I time the pull just right, I can gain on him sooner. I just have to stop being distracted by such a georgeous car!
Here is another example against a 1g DSM. You'll see here that I am neck and neck with him while the racelogic is in action:
Racelogic against 1g DSM
And for kicks, here is what it sounds like from the outsite. I gotta admit, it's a bit violent. I may have to retune the Racelogic or allow a bit more slip (it was at the Wet position).
Racelogic exterior violent sound
I had the racelogic tuned for my 26" r888s, but these 28" tires changed the ratios to the front wheels, making the traction control a bit more violent.
And big thanks to Greg for taking these videos!
2nd Pull with 997
