This one I didn't come up with. But when I read it, it hit me like a bolt of lighting.
There was a discussion I was reading on steam based anti-lag. Started out as injecting water into the exhaust to create steam to drive the turbo harder. After the discussion evolved a bit, one person, (username: andreasn99, I'd give full credit if I knew his/her name), posted the most amazing idea. Read....
Nice idea, but instead of using the steam to reduce turbo lag instead I am very sure u can produce a complete steamturbo system using the engine cooling water and extra heat by extracting the heat from the exhaust in the exhaust pipe as well. Either just cooling the walls or using a grid like a cooler inside an increased diameter part of the exhaust. This since an otto engine has an efficiency of about 30%, so 70 percent of the energy turns into heat and in a powerfull car like 500 hp u have approx 1000 hp of power in heat. Looking at the efficiency of the old steam engines of the past century that was using about 80% of the energy from the heat created. Using a good insulation in the system would create more then enough power to drive the turbo constantly. To make the system u can pretty much use a regular turbocharger of any make or kind even a cheap one since it will not have to take much heat and therefore bearings and material is not very important. U use a computer controled injector to inject the hot water in to a wide tube before the turbo preferably as wide as the turbos internal diameter. And since water naturally pass trough the exhaust part last it will hold a temp of approx 120+ degrees, to be able to cool the engine efficiently indepentent of the system u have a bypass hose to the cooler before the injection to the turbo that is controled by the thermostat. Also re-using the water in the system is possible by passing the steam through a pre-cooler simular to an intercooler turning the steam into water again before running it through the main cooler and then back in to the engine. The pre-cooler will be able to cool a massive amount of steam into water since the difference in temperature only have to be a few degrees, the bigger difference in heat, the more power extracted so the size of the pre-cooler is determined by the poweroutput wanted. In using this engine u will allways have enough heat to drive the system since the more power u need from it the more power the engine will produce in heat and it will allways be ready for more action instantly due to the pre-stored energy in the water. So now u have an integrated engine cooling system and turbo system that dont take any energy from the engine like a supercharger nor stopping or hindering the exhaust leaving the engine and the problems with lag created by a turbo system. With computer controlled valves and re-circulation valves u have complete control of the preload in the intake. Last but not least u might think u have no extra power from the charger before u get the heat up in the engine and my response to that is do not expect your car to last very long if u have racing car performance and using it before u get the engine up to temperature!!
Here's a follow up by WikdWaze, reinforcing a couple points:
[/b]The most brilliant solution of all was posted and largely ignored. Instead of using the exhaust gas pressure to power the turbo, use superheated steam from the cooling system. By using a much higher pressure in the cooling system you would allow the water to reach a higher temperature. This means you could run the water through jacketted exhaust manifolds like the offshore race boats use. The water would pick up additional heat from the exhaust, which has two advantages. First, it puts more energy into the water which can be harnessed by the turbine. Second, taking heat out of the exhaust gasses causes them to contract which reduces the pressure in the manifold. A lower pressure in the exhaust manifold helps scavenge the waste from the combustion chamber. This superheated water is then sent through a nozzle where it flashes to steam and spins the turbine. There would have to be a condensor to allow the steam to convert back to water before entering the radiator. This is quite possibly the perfect induction system. There is no belt drive causing power loss and no backpressure in the exhaust from a turbine, all the energy used to power the system is energy currently wasted. andreasn99, pure genius.[/b]
I agree. andreasn99, that solution is pure genius.
_______________________________________________
The approach that would work would be using a seperate pure water/steam system, heated by the exhaust. I wouldn't touch the cooling system. I'd want to get at least 100psi of pressure in the water container, and it would mean running the cooling temps crazy high and also require a super strong radiator, hoses, etc. I think there is more than enough heat energy in the exhaust. Like it says above, a IC engine is VERY ineffeicient, there is a TON of waste heat we can use. 2x as much HP in wasted heat as what ever gets to the ground.
I'm still doing math on how much water/steam, control, etc, but it may be practical. If it works, it would offer HUGE gains. The turbo would no longer be part of the exhaust. No back pressure in the exhaust (doesn't rob power), no HP cost in driving the turbine. Nearly instant boost any RPM, and I mean ANY RPM. Floor it from idle and hit 30psi in under a second. (EDIT: Not a good idea. Still have to consider compressor surge, but spool can be as soon as the compressor can handle it.) I imagine there would be some gain from the scavenging effect of the super cooled exhaust. Turbo could be anywhere, put in in the trunk. For people with a AEM, and if I can find a suitable solenoid or injector, you wouldn't even need a wastegate. Just modulate boost by the steam injection rate. Turbo should last longer, and add less heat to the intake charge, as it will be running very cool in comparison to having it run off the exhaust. The hottest temps the exhaust side will see will be 350F at most. Also consider the turbo will be sitting at idle, not spinning, except when you need it. Turbo life should be 10x as long.
I started thinking, naw it couldn't work. No way could you provide the volume of steam you would need. Well, it only takes about ~4.5GPM of water expanding to steam to generate 1000CFM of steam flow. That's not counting how steam is a FAR better medium to drive a turbine than hot exhaust gasses. Steam turbines are incredibly efficient. Also seeing as how we don't need to worry about creating a exhaust restriction, it would make sense to run very small turbines with large compressors. So, when everything is accounted for, it probably won't take much super heated water, released from a nozzle, to drive the turbine.
I'll get back as I learn more about the behavior of steam vs exhaust gasses through a turbine. Basically, I'm trying to figure out if I have X exhaust flow, it should take Y steam flow to duplicate the power delivered to turning the turbine.
I already know how I can conduct a practical test of the idea. All I would need is a turbo, any turbo, a used stocker would work fine. I'd seal off the entrance to the turbine side, and install a nozzle and solenoid there. From the solenoid I would have a stainless line run to a steel gas cylinder, which would be heated until I get the pressure I'd like (undetermined as yet). Flip the cylinder upside down so I get water coming out. Activate the solenoid. Super hot, pressurized water will flow out of the nozzle, into the turbine. Once in the lower pressure of the turbine, it will instantly flash to steam, expanding at a rate of about 1600:1. I'd also install some sort of restrictor on the output of the turbo, whatever it takes to get it about 1BAR pressure in the compressor, to simulate the resistance of the engine. I'll could try different pressures and flow rates, at get a good idea of how much steam is needed to drive a turbo, and how fast the turbo will spool. I'd expect a almost instant spool up.
