2JZ-GTE Swap GS300 Build. Opinions/Help!
16K views 5 replies 3 participants last post by  Jormakka
#1 ·
Hey everyone, I'm not new to Supra Forum but I am new to posting and I wanted to see if anyone can help me out planning my build and give their thoughts and opinions! It's about time I introduce myself.
I apologize ahead of time if I don't give enough info.
(List of all mods at the bottom)
(800whp is the final goal)
So, I have a 1999 Lexus GS300 that was handed down to me as my first car. The car has been in my family for the past 10 years but has been in my possession since 2019. The car wasn't working when they gave it to me, so I fixed it up a little bit, gave it some love, and the car has been my daily ever since. I love it but the stock GE is to slow for my likings.
In June I decided to buy an Aristo 2JZ-GTE VVTI Engine with the auto transmission. It's been sitting my garage ever since because I've been taking my time planning and reading forums on how to prepare for a swap and figuring out what I would like done to the engine before I swap it. At first all I was going to do was a Single Turbo Conversion, light head work, and then continue with the swap. But my goals have changed, now I want to do a complete engine rebuild!
I'm thinking of doing a complete rebuild because I want the most reliable, responsive build I can possibly make. And I would like to be able to make as much power as I want without having to replace anything major. I'm trying to do it all on my first try (I know it's probably not possible lol). The build will be overkill.
My final power goals are 800whp on E85 and 600whp on pump gas with a lot of low-end torque because this is my daily/street car. I want my build to be capable of 800whp, but I will gradually build my way to up. I don't want to make that jump from 200hp to 800+. My first tune I want to make 400-500whp (If possible) then when I feel like I need more, all I need is another tune.
I'm open to hear anyone thoughts, opinions, questions, Etc.
Thank you in advanced for any help! I want to get started on the build sometime next month.
My mods will consist of:
  • Induction Performance Stage 2 Built Block (1000whp)
    • Induction Performance-spec Diamond Racing pistons W/ 86.5 Bore Size
    • 3.4L Brian Crower Stroker
    • Manley Turbo Tuff Tri-Beam Connecting Rods W/ ARP CA625+ Bolts
    • Billet Main Caps
    • ARP Main Studs
    • ACL Race Rod, Main and Thrust Bearings
    • 9.5:1 Compression Ratio
  • GSC S1 Cams
  • PHR (Powerhouse Racing) Cam Gears
  • Ferrea Valvetrain
  • Gates Timing Belt
  • ATI Super Damper
  • RSP Billet Timing Belt Tensioner
  • Induction Performance IGN1A Coil Kit
  • Radium Dual Catch Can Kit
  • PHR Street Torque Kit
    • PT6466 .81 Undivided Turbo
    • PHR Cast Manifold
    • Tial 44mm Wastegate - Recirculated
    • Tial Q BOV
  • ETS 4" Intercooler
  • Stock Intake Manifold
  • SP Quick Spool Valve
  • Koyo Radiator W/ PHR hose & pipes
  • Fuel System
    • Injector Dynamics 1300cc injectors
    • PHR Fuel Pump Hanger
    • 2 Walbro 450/485 Fuel Pumps
    • One -8AN feed line, one -6AN return line
    • Radium 10 Micron High Flow Filter
    • Radium Top Feed Fuel Rail
    • Radium DMR (Direct Mount Regulator) W/ Fuel Gauge
    • Radium Fuel Pulse Damper
    • ProEFI Flex Fuel Sensor Kit
  • ProEFI 128 ECU Kit
  • ATF Speed Stage 3 Auto Transmission (1000whp)
  • DSS or Driftmotion Driveshaft (Don't Know Yet)
  • OS-Giken LSD
  • DSS Axle (If I can get one custom made for the GS)
#2 ·
If you've got a 99 GS300 and a similar year Aristo 2JZ-GTE VVTi engine set with a non-immobilizer ECU, doing that swap is so fucking easy that I can't help but recommend that first.
If the only thing you're short is the non-immobilizer ECU, find one, and still do the swap.
With a basic bitch cheap front mount IC, and a similarly basic 3in exhaust that combo will be good for ~375whp barely trying, and with near-OEM levels of reliability and driving ease and everything else. Boost controller, catch can, and a few basic things like that and you'll be able to drive that car on road trips, have the A/C working perfect, and just have a nice kick ass Japanese touring sedan with modern-day levels of HP.
When the stock turbos die (they almost always die) decide from there on your path forward on doing a single turbo/built auto etc with the stock GTE block which is almost strong enough for your HP goals with 100% stock internals.
While enjoying all of that, I'd take the 2JZ-GE VVTi block you'll have left over, and build that shortblock on the side with your 3.4L kit when time/budget permits. You can easily use the GE block as a base for this, and install the 2JZ-GTE VVTi head to it when the time comes.
#3 ·
That would be a lot cheaper route and get the engine swap done faster.
Okay I have a couple questions.
How would I know if I have a non-immobilizer ECU and if I do decide to take this route instead of doing the full rebuild all at once, you think a CXRacing kit would work?
Wouldn’t the rods start to bend once I decide to do a single turbo build and get to 800whp with E85, PT6466, GSC S1 Cams, Cast Manifold, and SP QSV? From what I read the rods start to bend around 500tq and I feel like that combination would make over 500+ and have a lot of torque at the beginning of the powerband.
Wouldn’t the GTE be a better/easier block to build instead because it already has the turbo oil feed holes and oil squirters?
I never thought of building the GE block. Does it matter if it has over 280k+ miles?
#6 ·
Hi, how about the shifter change? I have a gs300 with the Aristo gte + tranny, but the gs300 shifter and instrument cluster. My shifter is stiff and the gears are not in the right place. Any good way to solve this. I do have the aristo shifter and instrument cluster available also, but I don't know if they will fit the gs300 center console. The ac piping for the rear vent is in the way of the rhd aristo shifter, if installed in the og rhd position.
